Problems with my 95 talon
FERGEYE
This just startin last week my car is like starving for gas everytime i turn a corner it slows rght down i think it wants gas.......I changed the fuel filter i think thats what it was then i cant find the pressure regulator neone have ne ideas what the prob is thank u
Sep 12, 2006 at 1:06 PM
FERGEYE
NONE knos where the fuel pressure regulator is? SOme one has to kno
Sep 15, 2006 at 4:57 AM
JOSHWITDATALON
  • 15 POSTS
The fuel pressure regulator is retained to the fuel rail by two bolts. if you are looking at ur motor it should be in front of and to the right a little bit of the throttle body. just look between the throttle body and the head, you shouldnt be able to miss it. and if everything is still stock under the hood it should have a light blue vacuum hose hooked up to it and then that line also hooks directly into the fuel pressure control solenoid valve. hope this helps ya out, let me know how it goes and if you have anymore questions.
Mar 27, 2007 at 7:30 PM
