95 Eagle Talon tsi AWD automatic performance problem
JASHIKA
  • 10 POSTS
Hi everyone!
I have a 95 Eagle Talon tsi AWD automatic 84k miles on it. I bought it with rod knock. I replaced the main and rod bearings and resurfaced the crankshaft and the rods. I didn't buy new pistons or rings because the compression was 155-160 psi. Everything seems fine with the engine now. The problem is that the car seems that it has not much power. Turbo screams so i guess that's all right. Check engine light is not on. If i put it in to drive or reverse it just stalls (most of the time but not every time) if i don't give some gas. The idle is about 800rpm so i think that's ok. I did a "torque converter stall speed test" on it and it was 2900 rpm, which is low because it needs to be between 3300-3800. Which means engine performance is poor or defective torque converter. I guess it's rather the engine or i don't know.
Does anyone have any idea ? The problem is that i ran out of money totally getting this car together so i can't take it to a shop.
Thank you!
Peter
Sep 18, 2007 at 10:52 AM
DIGITALRAIN
  • 5 POSTS
Sounds like you have a boost leak, Go over every fitting from the air filter to the manifold.
[quote:f8a31b0034="jashika"]Hi everyone!
Thank you!
Peter[/quote:f8a31b0034]
Oct 20, 2007 at 10:50 PM
JASHIKA
  • 10 POSTS
I'm pretty sure that all the hoses are good. I took apart every piece and checked them, i did't find any defects,leaking. Thank you anyways!
Peter
Oct 31, 2007 at 1:34 PM
