1998 Eagle Talon wont start
136,000 MILES • 4 CYL • 2WD • MANUAL
1998TALON
Hi I have a 1998 eagle talon the car turns over but does not start. Has ran for 4 to 5 months and when I do get it started it runs good I think its the fuel filter but any suggestions would be helpful thanks in advance
Sep 6, 2010 at 10:38 PM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sep 7, 2010 at 12:01 AM
1998TALON
Thanks for the suggestions will try to see if I have spark hope so since I changed the plugs out
Sep 7, 2010 at 2:14 AM
