1997 Eagle Talon won't start
115,077 MILES • 4 CYL • 2WD • AUTOMATIC
LOWELLDH
I just bought a 1997 talon. It started fine and drove it home. Later when I tryed to start it, it would not even turn over, All the lights work strong but not even a click. What am I in for? Starter? relay? bad connections? I need help as funds ar really tight. Thanks, Lowell
Dec 5, 2008 at 8:58 AM
  • 75,988 POSTS
Load test the battery to check its condition if okay do the same with alternator -if okay -you probably have a short somewhere within the electrical system draining the battery overnite-see below battery drain test
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_51.jpg
Dec 5, 2008 at 9:12 AM
MOKEY_18
I would check timeing! talons lazers and eclipse are zero tolerance engines! Noctorias for jumpin time! Fix it right away cuz if u keep crankin it will wreck cylinders ive taken aprt dsm numerus times and that seems to be the number 1 cause!
Jan 5, 2009 at 3:43 AM
  • 75,988 POSTS
Could be the ignition switch, park and neutral switch, starter relay and starter itself
Jan 5, 2009 at 5:29 AM
