1997 Eagle Talon code po100
10 MILES • 4 CYL • AWD • AUTOMATIC
ECLIPSETSI
my car is acting sluggish i run the codes and it gives me po100 i changed the sparkplugs but it still runs sluggish could it be the altinator
May 5, 2009 at 6:47 AM
WHITEBOYZRACING
  • 12 POSTS
[quote:9adf731a19="ECLIPSETSI"]Engine Performance problem
1997 Eagle Talon 4 cyl All Wheel Drive Automatic 10 miles
my car is acting sluggish i run the codes and it gives me po100 i changed the sparkplugs but it still runs sluggish could it be the altinator[/quote:9adf731a19]
A code P0100 may mean that one or more of the following has happened:
The MAF may be disconnected, or a wiring connection may be bad
The MAF sensor may be faulty.
That is why you are running sluggish. buy a new Maf or try cleaning it with a MAF/MAS ait cleaner from yur local parts store. it is located right after your airbox on the intake tube. it is a black plastic box with a harness connected to it, it reads the incoming air before going into the turbo. if you run into anymore problems just give me a holler.
Mar 6, 2010 at 2:21 PM
