1996 Eagle Talon P0301 Cylinder 1 Missfire Help
115,000 MILES • 4 CYL • FWD • MANUAL
CHOPLOPS
I have a 1996 eagle talon and the code seems to come up about 10 minutes after its been idling, it doesnt seem to be idling rough. I had a mechanic check the compression and that was good, and the mechanic changed the plugs, and I replaced all the fuel injectors and the intake plenum gasket, I also switched the plug wire from cylinder 1 and cylinder 4 and I am still getting this code, anybody have an idea what this might be?
Mar 3, 2009 at 11:53 AM
BLACKOP555
  • 10,386 POSTS
with vehicle running groudn out the #1 cylinder, does it change the vehicles driveability any?
Mar 3, 2009 at 1:22 PM
