1996 Eagle Talon
ARU1Z
Electrical problem
1996 Eagle Talon 4 cyl Front Wheel Drive Automatic
this car has a remote starter, this may or may not have anything to do with the problem? anyway when you turn ignition off car stays running. if you put tranny in drive car would stop running. if you put car back in park WITHOUT turning ignition on the car trys to start? now can't get car out of park and had to disconnect the batt. so it doesn't start on it's own?
Apr 19, 2009 at 12:25 AM
BMRFIXIT
  • 19,053 POSTS
1st step would be to locate and disconnect remote starter module most common place to be is driver side under steering area
let me know
Apr 19, 2009 at 12:42 AM
