are the rod bearings for a non-turbo talon the same as a talon with a turbo?
Mar 20, 2008 at 9:58 AM
✓Experienced Mechanic
What are you trying to do here swap bearings bad idea-mike the crank or use the plastigauge and select the correct undersize bearings.
Mar 20, 2008 at 10:28 AM
