1995 Eagle Talon oil pressure light switch
195,000 MILES • 4 CYL • FWD • MANUAL
CHTORRALBA
[img:d0e1f6c7a2]http://www.2carpros.com/forum/automotive_pictures/525644_48588755_1.jpg[/img:d0e1f6c7a2]
Quick question for you guys. My oil pressure light switch connector is leaking oil where the 2 wires come out as shown on the attached picture. Which part is faulty here.. the connector or the oil pressure light switch unit?? I don't really want to spend $117 for the unit if i don't have to. Thanks in advance!
May 9, 2010 at 4:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if oil is coming out there from the connector then the connector must be at fault, otherwise it would be leaking at the actual switch where it connects to block .
May 9, 2010 at 2:02 PM
