1995 Eagle Talon oil and air filter
125,348 MILES • 4 CYL • FWD • MANUAL
SNOW_ANGL_25
my car is an 95 eagle talon esi
1.where is the oil filter located
2.where is the air filter located
3.where is the fuel filter located
4.my dash board light went out what could be wrong with it and how do you fix it
5.where is the oil pan located
Oct 24, 2009 at 10:42 AM
WHITEBOYZRACING
  • 12 POSTS
[quote:502015f912="snow_angl_25"]Engine Mechanical problem
1995 Eagle Talon 4 cyl Front Wheel Drive Manual 125348 miles
5.where is the oil pan located[/quote:502015f912]
1) Your oil filter is located under the car on the driver side.
2) on the driverside under the hood you will see a black rubber hose coming off going into a plastic box, that is called the airbox you unbolt the top and inside of there is you air filter.
3) on the pass side on the firewall.
4)need more info, as did all the lights go out of just one of em.
5) your oil pan is located under ur motor, it is held on by 10mm bolts. it is black, that is where your drain plug is located wich is a 17mm and that is how you drain the oil out of you car.
Mar 6, 2010 at 1:08 PM
