1995 Eagle Talon Help Please
TDUNCAN3
Hi, 2 weeks ago the fuel pump went out on my car I replaced it. Was running great. Then today it appears like the same problem however, car will start then dies. Any sugguestions.
Jan 20, 2006 at 12:31 PM
2CARPRO JACK
  • 11,533 POSTS
fuel pump relay or ignition switch
Feb 3, 2006 at 7:47 AM
94BOWDEN
  • 33 POSTS
it has nothing to do with the ignition switch but fuel pump relay...... very possible. Also check for faulty wiring.
Aug 3, 2006 at 5:44 AM
FERGEYE
Man my car is hesitatin n when i go around corners it wants to stall out neone have ne idea whats going on
Sep 12, 2006 at 1:03 PM
JOSHWITDATALON
  • 15 POSTS
It could be a loose or faulty electrical connections at the distributor(or crank angle sensor). not enough fuel reaching the injectors. could very likely be a vaccum leak at the gasket between the intake manifolf and the throttle body, or between the intake manifold and the engine. hope this helps ya out. let me know how it goes and if you have any more questions.
Mar 27, 2007 at 7:37 PM
KOJAKTRD
coud be the throttle position sensor (TPS).
Apr 8, 2007 at 4:15 PM
Suggested Repair
Check the fuel pump relay and ignition switch, and inspect related fuel-pump wiring for loose or faulty connections.
Conversation Summary
The owner of a 1995 Eagle Talon said the car starts and then dies after a recent fuel pump replacement. The expert suggested checking the fuel pump relay or ignition switch. Another reply agreed the relay was possible, ruled out the ignition switch, and recommended checking the wiring. Later comments described hesitation and stalling in corners and mentioned distributor or crank-angle sensor connections, fuel delivery, vacuum leaks, and the throttle position sensor.
