1995 Eagle Talon companion cylinders not firing right
100,000 MILES • 4 CYL • AWD • AUTOMATIC
UTI
the 2 center cylinder spark plugs hav a burnt residue on them, and the outside ones just smell like gas and dont have any burn marks... spark plugs are bran new never used, just replcaed the head gasket and fuel rail
Feb 27, 2010 at 11:46 AM
DOCFIXIT
  • 18,828 POSTS
Are all plugs firing? does engine run on all cylinders? did timing belt break?
Feb 28, 2010 at 7:31 AM
UTI
the belts are all fine, the motor runs, it just dies out, and the center 2 are firing for sure (2&3) and the out side ones (1&4) plugs smell like gas and are wet, but the plugs, wires and coil packs are still fine 2,.. would the wiming be off by 180 do you think?
Feb 28, 2010 at 7:46 AM
DOCFIXIT
  • 18,828 POSTS
Check compression then post results
Mar 1, 2010 at 3:06 AM
UTI
k, now the problem is that somewhere near the coil a wire is loose or something, I switched coils and they would produce spark, did a bunch differant combo's of coils, and it seems like the coil that controls 1 and 4 isnt working right (brand new coil).. it is just trying to turn over like theres no gas in it
Mar 2, 2010 at 3:59 PM
