1994 Eagle Talon turbo troubles
76,000 MILES • 4 CYL • FWD • MANUAL
STACEYVWRIGHT
when the boost comes to 7 lbs. the engin sputters and falls on its face. engin runs great up to that point . any advice?
Nov 2, 2009 at 12:17 PM
WHITEBOYZRACING
  • 12 POSTS
[quote:81d690c36e="staceyvwright"]Engine Mechanical problem
1994 Eagle Talon 4 cyl Front Wheel Drive Manual 76000 miles
when the boost comes to 7 lbs. the engin sputters and falls on its face. engin runs great up to that point . any advice?[/quote:81d690c36e]
r is it like hitting a brick wall? when it sputters? what happens ? does the boost gauge drop lower? you could be getting fuel cut.? or you have a boost leak.
I take it you have an aftermarket boost gauge ? also do you have a manual boost controller ? any mods ? more info please. and thank you
Mar 6, 2010 at 2:07 PM
