1994 Eagle Talon engine miss
1994 EAGLE TALON
100,000 MILES • 4 CYL • FWD • MANUAL
MRL5201
My car seems to start hesitaing somewhat when i get to about 3,000 rpms its not a major miss but i would like to try to solve the problem if i can, i recently had a fuel problem with the car and had to change the fuel filter on a regular basis, there was something in the gas tank that clogged up the fuel injectors and made one of my cylinders stop firing, had to put alot of money into it to get it back in good running condition, im 21 years old and this is my first 5 speed and its a pretty quick car and i have a tendency to rev the engine up pretty high, could that maybe be the cause, or what problems could i cause by doing that, I was told the engine compression and everything was good when I got it fixed, said the car should last a while, If you could help by answering any questions above that would be great......Thanks alot
Matt-
Dec 8, 2007 at 2:26 AM
MANDERS272
Be very careful with that motor, the are known for ceasing. make sure your timing is set right and your timing belt is right. my timing belt snapped on my 93 eagle talon and took out everything. the motor was un-fixable. if this does happen (which i hope it doesn't), you can purchase a new motor for just $800 on ebay from Japan. I now have a new Japan motor in mine and it's running mint. good luck!
Dec 12, 2007 at 2:54 PM
