1993 Eagle Talon Won't Start
NICOLEMULKEY
Other Category problem
1993 Eagle Talon 4 cyl Wheel Drive Type unknown Manual unsure miles
The other day my car stopped starting. We thought we narrowed down the problem to the distributor. It's turning over but there is no fire to the engine. Replaced the distributor but that's not the problem, it's still doing the same thing. Turning over but not firing. HELP!!!
Jan 17, 2008 at 10:04 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2f05230bb1="NicoleMulkey"]Other Category problem
The other day my car stopped starting. We thought we narrowed down the problem to the distributor. It's turning over but there is no fire to the engine. Replaced the distributor but that's not the problem, it's still doing the same thing. Turning over but not firing. HELP!!![/quote:2f05230bb1]
its been a long time since I ve seen or worked on one but I thing they have a crank sensor if so change it.
check also the relays
Jan 17, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4ae411ae83="BMRFIXIT"][quote:4ae411ae83="NicoleMulkey"]Other Category problem
The other day my car stopped starting. We thought we narrowed down the problem to the distributor. It's turning over but there is no fire to the engine. Replaced the distributor but that's not the problem, it's still doing the same thing. Turning over but not firing. HELP!!![/quote:4ae411ae83]
check also the relays[/quote:4ae411ae83]
Inbox :: Message
To: BMRFIXIT
Posted: Thu Jan 17, 2008 2:27 pm
Subject: Eagle Talon won't start
So where can I get a picture or something to help locate the crank sensor, or can you give me a little description of where that may be. I let my boyfriend know that I got a response from this site, and he said he wasn't quite sure where the crank sensor was. Like I said, it sounds like it wants to start it just won't fire to start up. It will sit there and turn and turn but no fire whatsoever.
need engine size
did your friend check for spark
out of the spark plugs when cranking
location depend on engine size
most likely its at the rear cylinder head
some have it inside the distributor
let him check for spark and let me know
Jan 18, 2008 at 5:38 AM
