1993 Eagle Talon stalling
125,000 MILES • 4 CYL • FWD • MANUAL
19DL49
car will start then in a few minutes you will hear a fairly loud clicking noise ,sounds like right side of engine compartment and engine will die.it may or may not start back up right away.I always manage to get it home but it may take awhile.check engine light comes on while it clicks then goes out.Sounds like a switch or relay clicking or a injector? dklinder@twlakes.net Maybe not much but I paypaled you.THanks
Dec 13, 2007 at 4:49 AM
2CARPRO JACK
  • 11,533 POSTS
Have you had it scanned to see if it stored a code? The only relay I can see in that block that could possibly kill the engine is the alt relay. Try swapping it for the headlight relay and see if it dies
Dec 13, 2007 at 10:40 AM
