1993 Eagle Talon engine swap
130,000 MILES • 4 CYL • FWD • MANUAL
WIKID-_-EAGLE
can anyone tell me how i would do an engine swap from my 1.8L engine to a 2.0 Turbocharged from another eagle talon
would i need the whole other car with the engine, would my transmission bolt up the same or would i have to swap transmissions too, would i need to change my car to the AWD
any help would be useful
Oct 10, 2008 at 4:50 AM
F150NEWBIE
  • 6 POSTS
If you havent purchased the turbocharged engine yet, I would highly suggest buy a 6 bolt engine. These 6bolts are less prone to crankwalk compared to the 7bolt. The 6bolt are from years 90-92.5. What you will need is the engine (block, head, intake manifold, exhaust manifold, and intercooler and piping), ecu ( make sure it has eprom) & wiring harness. This is all I can remember from the top of my head. As far as the transmission, I am not sure if it will bolt up. Most people will suggest youre better off selling what you have for a turbocharged model. Its a hassle, but it can be done. No, you dont have to change to an AWD.
Nov 2, 2008 at 4:41 AM
