1992 Eagle Talon Engine Idle
200,300 MILES • 4 CYL • FWD • MANUAL
SUPERKIDDY
Hey, my car idle surges. I replaced the ISC, blocked off the EGR Valve, replaced the ECU. None of that stopped it. I just recently messed with the idle sensor? (it's the little thing that screws into the throttle and a wire plugs in the top of it). I got it to where it was a steady idle, but high. Then I tightened the BISS screw all the way and that put the idle about where it should be. I then realized, it's only idling correctly when it's warm, when it's cold, it surges and/or idles high. I was told that my intake manifold could be leaking, and to spray carb cleaner around it to see if it is. Could that be the problem, even though it's not a constant thing? Would spraying carb cleaner around the manifold hurt my engine at all? Thanks for the help in advance. Gary
Jun 10, 2008 at 7:56 AM
LEGITIMATE007
  • 5,121 POSTS
no it wont hurt it, you just gently mist it around your manifold and vacuum hoses, when and if you hear a surge in your idle ,thats where your leak is, now it may do that in several places, then of course you have several leaks
Jun 10, 2008 at 8:00 AM
