1990 Eagle Talon Removing driveshaft
BLUEOLDSCUTLASS
Drive Train Axles Bearings problem
1990 Eagle Talon 4 cyl All Wheel Drive Manual
Is there a special method to pull the front driveshaft yoke out of the transaxle? We are removing the engine transaxle assembly and we can't pull the the driveshaft backwards.
Feb 4, 2010 at 11:50 AM
WHITEBOYZRACING
  • 12 POSTS
If you are tryn to pull the drive shaft out, you need to remove the transfer case, there are (5) 17mm bolts that hold the transfer case to the transmission then u just pry it off the input shaft on the trany and remove the driveshaft. or if you are talking about the front axles you have to remove the axle nuts wich are 32mm.
Mar 6, 2010 at 12:50 PM
