1990 Eagle Talon clutch
1990 EAGLE TALON
BURNINGNATIVEANGEL
1990 Eagle Talon 4 cyl Front Wheel Drive Manual
on our talon tsi turbo our clutch will not engage we have replaced the engine flywheel master and slave clutch and still cannot get it to engage what can i do? we also checked the 14 bolt on the pedal to adjust i am out of ideas
Dec 1, 2009 at 7:28 PM
WHITEBOYZRACING
  • 12 POSTS
[quote:001b48ef92="burningnativeangel"]1990 Eagle Talon 4 cyl Front Wheel Drive Manual
on our talon tsi turbo our clutch will not engage we have replaced the engine flywheel master and slave clutch and still cannot get it to engage what can i do? we also checked the 14 bolt on the pedal to adjust i am out of ideas[/quote:001b48ef92]
The clutch does not engage at all ?
you can try these.
The pivot ball behind the clutch fork wears out over time, you can either replace or shim that with a washer, and also you can by a extended clutch rod if you needed to. I would like more info before you try either of them. I have been working on DSM's for over 5years now, and I own 4 of them. please let me know more. thank you.
Mar 6, 2010 at 8:44 PM
