1990 Eagle Talon Acceleration Problems?
81,000 MILES • 4 CYL • AWD • MANUAL
SNOWCONE_10
Doesnt happen all the time, but most of the time. When i gas it the car almost stalls. i can feel it hold the boost and then after a bit it kicks when it catches. i took it in and the mechanic said he thinks its my mass airflow sensor so i replaced that and it decreased the frequency but it still does it often, i now have no idea. the mech checked the fuel pressure and that was fine so yeah. PLEASE HELP!
Jul 21, 2010 at 7:16 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jul 21, 2010 at 9:31 PM
