1995 Eagle Summit turn signal
1995 EAGLE SUMMIT
17,600 MILES • 4 CYL • FWD • MANUAL
JUNE SVENSON
my left turn signal won't shut off,when I turn to the left I can here it click like it should.And now the right one won't work at all.There is power going to the right side the light just won't work.
Jul 30, 2010 at 2:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if signal will not shut off then switch is most likely culprit but is best to always check easiest first which would be signal flasher relay.
Jul 31, 2010 at 1:30 AM
