1994 Eagle Summit Wiper problems
1994 EAGLE SUMMIT
134,000 MILES • 4 CYL • 2WD • MANUAL
FSTEELERFAN
How does the 94 Eagle Summit wipers work? I hear the motor running but some where between the wiper motor and the blades something isn't working because the wipers aren't turning. So I know its not the fuse. I've never had any problems with my Eagle This all happened after an ice storm and I tried to turn the wipers on I thought I cleaned all the ice around the wipers but still nothing I turned the wipers on and then tried to manually move the wipers while they were still turned on.and they manually moved. Thank you
Dec 27, 2007 at 11:37 AM
  • 31,937 POSTS
there is a regulator (linkages) between the wiper motor and the wiper blade arms, the pivot on the wiper are has probably failed and a new regulator will be required.
Mark (mhpautos)
Dec 28, 2007 at 9:17 PM
