1994 Eagle Summit
1994 EAGLE SUMMIT
SIRENA4076
Transmission problem
1994 Eagle Summit 4 cyl Automatic
the car was running fine, was running errand and stop at light when the car stalled out. started backup with no problem, but when put car in drive it wont move. will not move in any gear.
Mar 31, 2010 at 12:21 PM
DOCFIXIT
  • 18,828 POSTS
Does engine rev up like in neutral?
Apr 1, 2010 at 7:14 AM
SIRENA4076
no it idle normal
Apr 4, 2010 at 3:51 AM
DOCFIXIT
  • 18,828 POSTS
No I mean when gas pedal is depressed does engine rev up while in gear
Apr 5, 2010 at 12:42 AM
SIRENA4076
When you press gas it sounds like it wants to go, but the car does not move, so yes it rev up
Apr 5, 2010 at 4:19 AM
DOCFIXIT
  • 18,828 POSTS
Check fluid level and color. If dark brown to black and has burnt smell then clutches it direct clutch pack smoked. Car is in need of trans overhaul or replacement
Apr 6, 2010 at 12:42 AM
