1992 Eagle Summit TORQUE SPECS FOR CONNECTING ROD AND ROCKE
PEDRON PALE
Engine Mechanical problem
1992 Eagle Summit 4 cyl Automatic 142457 miles
NEED TO KNOW TORQUE SPECS. FOR SUMMIT ENGINE YOU REPLY IS APPRECIATED
Jun 6, 2010 at 5:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
1.5L or 1.6L engine?
Jun 6, 2010 at 5:40 PM
PEDRON PALE
I NEED TO KNOW TORQUE SPECS FOR CONNECTING ROD BEARING BOLTS AND ROCKER ARM BOLTS IT IS A 1.5 LITER ENGINE. PLEASE REPLY.
Jun 7, 2010 at 6:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
connecting rod bolt tighten to 15 ft. lbs., then tighten nut an addition 1/4 turn. rocker arm bolt tighten to 21 - 25 ft. lbs.
Jun 8, 2010 at 8:02 AM
PEDRON PALE
WHAT IS THE TIGHTENING SEQUENCE FOR THE EAGLE SUMMIT CYLINDER HEAD AND TORQUE?
Jun 8, 2010 at 10:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
cylinder head bolts torque in 2 - 3 stages, finishing with 53 Ft. Lbs . follow sequence below
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_562.jpg
Jun 8, 2010 at 3:10 PM
