1992 Eagle Summit TORQUE SPECS
PEDRON PALE
Engine Mechanical problem
1992 Eagle Summit 4 cyl Front Wheel Drive Automatic
WHAT IS THE TORQUE SPECS FOR ROCKER ARM AND CONNECTING ROD BOLTS?
Jun 8, 2010 at 10:44 AM
  • 75,988 POSTS
Here you go
Rod bolts torque it 15ftlbs and turn it 1/4 turn
Rocker arm adjuster lock nut: 10-13ft lbs
Rocker arm shaft bolt: 21-25ft lbs
Jun 8, 2010 at 11:13 AM
