1992 Eagle Summit ignition control module
EEL
Electrical problem
1992 Eagle Summit 4 cyl All Wheel Drive Automatic
where is the ignition control module located in a 1992 eagle summit wagon with a 2.4 liter engine?
Jul 5, 2009 at 9:40 PM
DANAUTHIER
  • 156 POSTS
Here is the location of all the control modules in your veehicle, hope this helps
Multi-Point Injection (MPI) control unit --located under the instrument panel at the top of the passenger side kick panel next to the blower motor.
Air conditioning control unit --mounted behind the glove box.
Automatic transaxle control unit --mounted on the floor at the very front of the console.
Cruise control unit --under the instrument panel behind the driver's side knee protector.
Electric door lock control unit --fastened to the body structure behind the driver's side kick panel.
Automatic seat belt control unit --under the console next to hand brake handle.
ELC 4-speed automatic transaxle control unit --under the console next to hand brake handle.
Anti-lock Braking System (ABS) control unit --under the instrument panel at center of dash.
Jul 19, 2009 at 11:20 AM
