1991 Eagle Summit no spark
155,000 MILES • 4 CYL • FWD • MANUAL
KDJOHME
  • 7 POSTS
changed distributor ignition module and cap and rotor (complete distributor) spark plugs .
also fuel filter .
ran great then stopped running awhile driving .
cranks easy no spark .
mark old dist. with ink , placed new one same alignment .
is there a cumputer chip ? timing belt / chain ?
what direction should i go next ?[img:49db5c17df]http://www.2carpros.com/forum/automotive_pictures/383782_1991_eagle_summit_15L_engine_001_1.jpg[/img:49db5c17df]
[img:49db5c17df]http://www.2carpros.com/forum/automotive_pictures/383782_1991_eagle_summit_15L_engine_002_1.jpg[/img:49db5c17df]
[img:49db5c17df]http://www.2carpros.com/forum/automotive_pictures/383782_1991_eagle_summit_15L_engine_003_1.jpg[/img:49db5c17df]
[img:49db5c17df]http://www.2carpros.com/forum/automotive_pictures/383782_1991_eagle_summit_15L_engine_008_1.jpg[/img:49db5c17df]
[img:49db5c17df]http://www.2carpros.com/forum/automotive_pictures/383782_1991_eagle_summit_15L_engine_004_1.jpg[/img:49db5c17df]
Jul 17, 2009 at 8:39 AM
  • 75,988 POSTS
At the coil positive terminal do you have battery voltage on the black and white wire and the black wire if not check the ignition switch and the MPI control relay.
Jul 17, 2009 at 10:39 AM
KDJOHME
  • 7 POSTS
with key on , i check voltage at the wire tremital with 6 wires bottom of distrubutor . the black has 0 the blk/wht has 12 volts . none when key is off .
don't know what a MPI crontrol relay is ? ignition swicth ?
how much do you want to walk me thur this ?
the yellow wire had some caseing damage some bare wires show. nothing burnt .
Jul 24, 2009 at 5:50 AM
  • 75,988 POSTS
Turn key on check for power on the 2 wire connector at the coil-black and white wire power there and still no spark test the crank and TDC sensor-No power its coming from the ignition switch.
Jul 24, 2009 at 7:24 AM
KDJOHME
  • 7 POSTS
i tested the 2 wire connector at the distrubitor with key on .... blk/wht wire is hot with 10 volts .
is there a manaul with picture i can get ?
whats next ?
Jul 30, 2009 at 10:44 AM
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_ewd_4.jpg
Jul 30, 2009 at 12:10 PM
KDJOHME
  • 7 POSTS
thanks, i'm not able to read , where and how do i check the tdc sencer you ask me to check , or do i need to know ?
Jul 31, 2009 at 8:34 AM
  • 75,988 POSTS
Do you have code 22? scan the computer for codes and if any comeback with it, The crank angle sensor is in the distributor
Jul 31, 2009 at 8:57 AM
KDJOHME
  • 7 POSTS
i have no decoder .
i've replaced the distributor .
what else can i replace that might help ?
or should i give up and take it to a chryslar dealer ?
i cann't find a repair manual for the 1.5 l engine wiring . thanks for all your help kenny j .
please respond ..
Aug 17, 2009 at 7:21 AM
  • 75,988 POSTS
Give me your email addy and I'll send it thru there and see what happens
Aug 17, 2009 at 9:07 AM
KDJOHME
  • 7 POSTS
kdjohme@frontiernet.net
kenneth d johme
24564 noble ave
le mars , ia 51031
712 546 7461 hm
712 281 2869 cell
Aug 17, 2009 at 10:07 PM
  • 75,988 POSTS
Hope this helps-this is as far I can do it
https://images.2carpros.com/forum/automotive_pictures/12900_eagle1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_eagle2_1.jpg
Aug 18, 2009 at 6:49 AM
