1991 Eagle Summit new alternator not working
140,000 MILES • 4 CYL • FWD • AUTOMATIC
RAMZA666
  • 5 POSTS
just bought a new alternator, had a little trouble attaching the metal band to the post on the alternator cause it was in a slightly different location.
however i got it installed, with all the plugs on and when i jump the car, it dies in 10 minutes, or less if i turn on the lights. i am at a loss
Dec 3, 2008 at 7:31 AM
  • 31,937 POSTS
HI there,
With the engine running, check the Voltage at the main alternator terminal, check it with the car at around 1500 RPM, report back the reading for more advice.
Mark (mhpautos)
Dec 3, 2008 at 7:34 AM
RAMZA666
  • 5 POSTS
which is the main terminal
Dec 3, 2008 at 7:36 AM
RAMZA666
  • 5 POSTS
i dont have a voltage tester.
Dec 3, 2008 at 7:47 AM
RAMZA666
  • 5 POSTS
when i jump the car, and let it run, i believe that if the alternator was functioning it should run without the battery. however when i remove the battery cable, the car dies. does this mean that my alternator is installed incorrectly?
Dec 3, 2008 at 8:04 AM
  • 31,937 POSTS
HI there,
You should never run the engine with the battery disconnected , you can cook the ECU so easily and do other electrical damage, but as you have done so, it only shows that the battery voltage is enough to run the required systems, you will need to get the alternator readings so i can sort out your problem.
Mark (mhpautos)
Dec 3, 2008 at 11:15 AM
