1990 Eagle Summit timing marks
142,000 MILES • 4 CYL • 2WD • AUTOMATIC
BELZONIBOY
i recentkly replaced the timimg belt on this vehicle and it won't start, i noticed oily coolant in my radiator and i drained it, do i need to drain the oil as well and replace both to see if engine will start?
Dec 14, 2009 at 4:39 AM
  • 75,988 POSTS
Did you put engine no.1 piston on its compression stroke/TDC and line the crank and cam before you put the belt on?? If not it will cause your problem of no start.
Dec 14, 2009 at 6:36 AM
