e350e white smoke?
133,600 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
MERC12345677
e350e is smoking a lot of white smoke and only giving 2 codes on launch P22797A and P06DA00
Nov 7, 2025 at 6:36 PM
  • 55,658 POSTS
The first thing I would do is check the engine oil level and the engine coolant level when the engine is cold. If the engine oil is over filled it can cause white smoke, also if you have a blown head gasket the coolant will be low and the white smoke will have a sweet/pungent smell.
P2279-7A - Intake Air System Leak
P06DA00 - Engine Oil Pressure Control Circuit Performance
Also, remove the oil fill cap on the engine to see if it has a brown/whitish goo, this will be a sign the engine coolant is leaking inside the engine. Please go over this guide for more information.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Please upload a short video in your response of the problem, so we can see what's going on.
Nov 9, 2025 at 2:50 AM
