w210 ECM no communication with scan tool
99,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
ALECKOWALCZYK
hi, i have a check engine light on my car.
trying to read code with my launch diagun scanner with 38 pin adaptor, car has no 16 pin connector under dash.
i cant communicate with ECM at all but can talk to transmission, brakes. etc., no problem.
engine light comes on with ignition, quick check of fuses found nothing.
tried selecting different years on scanner with no luck.
any suggestions welcome. thank you, Alec
Nov 24, 2019 at 2:17 AM
So you have a direct line of communication from the DLC to the ECM so we need to look at these lines and make sure you don't have a wiring issue, ground issue, or a terminal fitment issue in one of the connectors.
I would make sure the wires have continuity from the DLC on Pin 4 and 13 to the ECM on Pins 39 and 38. If you do then do a drag test on the terminals. You will need a test kit to do this. You can get those at most any parts store.
If you don't have a wiring issue I suspect the ECM is the issue. Even though the engine light comes on with the ignition doesn't mean there isn't an issue on this portion of the circuit board.
Let me know if you have questions and we can go from there.
Nov 25, 2019 at 8:41 AM
ALECKOWALCZYK
thank you for your reply, much appreciated. i will test tomorrow and let you know the outcome.
Alec
Nov 26, 2019 at 10:33 AM
Sounds good. We will wait to hear back from you.
Nov 26, 2019 at 10:47 AM
