Stalling while driving
198,000 MILES • 1.2L • 4 CYL • FWD • AUTOMATIC
JORDAN ALEXANDER
When I cold crank and drive it will go for a few miles before the check engine, battery, and oil lights come on it will die. I have to wait a few minutes until it will crank again.
May 15, 2016 at 7:20 AM
HMAC300
  • 48,601 POSTS
check battery for condition including load test and check charging at same time most places do for free including auto parts.
Dec 16, 2019 at 2:35 AM
JORDAN ALEXANDER
It has a new battery, but I did suspect possibly needing new terminal. I do not know if it is relevant, but the car also idles up and down.
HMAC300
  • 48,601 POSTS
clean the throttle plate and iac hole with choke cleaner both sides of plate and check for a vacuum leak like a broken hose one off etc.
JORDAN ALEXANDER
Alright, I will try that and get back.
JORDAN ALEXANDER
So funny thing, I cannot crank the car because I am replacing the oil pan currently, but I went to clean the carburetor and there was a piece of cardboard someone put in there, what the heck?
  • 55,746 POSTS
Hey Jordan,
I have seen where the distributors in these engine go bad, can you remove the cap to see if there is any rust powder inside of it? This is a sign its going bad.
Best, Ken
