Dyed while driving now won't start
190 MILES • 3.0L • 6 CYL • AUTOMATIC
LISAANDKIDS
Dyed while driving wouldn't start back up. Changed oil, oil filter,spark plugs and wires and ignition coil, long to start, when it did it idled for a little bit then drove around corner then dyed again and won't start and its cranking and cranking but won't start now it killing battery cause it won't start. Please help have 6 kids that go to 4 different schools and can't afford
to buy another car can pretty much do everything on my own
Mar 25, 2017 at 3:36 PM
CATAFINA
  • 98 POSTS
Check your fuel pressure here's how its done:https://www.2carpros.com/.../how-to-check-fuel-system-pressure-and- regulator, then comeback with results
Mar 25, 2017 at 5:23 PM
STEVE W.
  • 15,414 POSTS
As MACKINBLUE said, check the fuel pressure as a start. Key On engine off pressure should be between 35-45 PSI. Check the inertia switch as well before condemning the pump.
Mar 25, 2017 at 11:12 PM
