dust shield-brake drum dust guard
240,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
TEGO
  • 9 POSTS
how to replace rusted out brake drum dust shield?
Dec 28, 2020 at 11:22 AM
  • 110,248 POSTS
I'm not sure if it is the front or rear, but they are very similar. I checked the manual and there is nothing listed for replacement, but I'll try to explain it.
First, you will need to remove the wheel. Once the wheel is off, remove the brake caliper, brake caliper mount, and then you can remove the brake rotor. Behind the rotor are the bolts that hold the dust cover onto the steering knuckle.
Here is a link that explains in general how to replace brakes and rotors. These directions will walk you through to removal of the rotor. At that point, you will need to unbolt the backing plate (dust shield).
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
I attached a pic specific to your vehicle below. Everything needs to be removed except what I highlighted.
Let me know if I can help or if you have other questions.
Dec 28, 2020 at 3:57 PM
CARADIODOC
  • 34,413 POSTS
Happy Tuesday to you, Joe.
I think he's referring to the rear as he mentioned "drum" brake. Suppose he means the backing plate? Does an axle shaft have to come out, or is there a bolt-on wheel bearing?
Dec 29, 2020 at 6:02 AM
TEGO
  • 9 POSTS
Hi Joe,
Thanks for your reply. But as Caradiodoc mentioned. I am referring to the rear backing plate. I know that I have to remove the parking brake assembly. But do I have to take off the wheel hub also to replace the rusted backing plate? See image of wheel hub and rusted off portion of plate. Thanks.
Tego.
Dec 29, 2020 at 2:54 PM
  • 110,248 POSTS
Hi:
Sorry about that. I'm not sure why I jumped to the front.
Anyway, yes the hub needs to be removed because it is actually mounted with the same bolts that hold the hub on. See pic 1.
________________
Take a look through these directions and let me know if they help.
_______________
2004 Toyota Truck Highlander 4WD V6-3.3L (3MZ-FE)
Rear Axle Hub & Bearing Assy LH Replacement
Vehicle Steering and Suspension Wheels and Tires Wheel Bearing Service and Repair Procedures Rear Axle Hub & Bearing Assy LH Replacement
REAR AXLE HUB & BEARING ASSY LH REPLACEMENT
REAR AXLE HUB & BEARING ASSY LH (4WD)
REPLACEMENT
HINT:
COMPONENTS:
1. REMOVE REAR WHEEL
2. SEPARATE SPEED SENSOR REAR LH
pic 2
3. REMOVE REAR AXLE SHAFT LH NUT
(a)Using SST and a hammer, unstake the staked part of the axle hub LH nut. SST 09930-00010
NOTICE: Loosen the staked part of the nut completely, otherwise the screw of the drive shaft may be damaged.
(b)While applying the brakes, remove the lock axle hub LH nut.
pic 3
4. SEPARATE REAR DISC BRAKE CALIPER ASSY LH
(a)Remove the bolt, and separate the flexible hose from the shock absorber.
(b)Remove the 2 bolts and separate rear disc brake caliper assy.
NOTICE: Use a string or other device to keep the brake caliper from hanging down.
5. REMOVE REAR DISC
pic 4
6. REMOVE REAR AXLE HUB & BEARING ASSY LH
(a)Remove the 4 bolts and the rear axle hub & bearing assy LH.
pic 5
7. INSTALL REAR AXLE HUB & BEARING ASSY LH
(a)Install the rear axle hub & bearing assy LH with the 4 bolts. Torque: 75 Nm (765 kgf cm, 55 ft.lbf)
8. INSTALL REAR DISC
pic 6
9. INSTALL REAR DISC BRAKE CALIPER ASSY LH
(a)Install the rear disc brake caliper assy LH with the 2 bolts. Torque: 78 Nm (800 kgf cm, 58 ft.lbf)
(b)Install the flexible hose with the bolt to the shock absorber.
Torque: 19 Nm (192 kgf cm, 14 ft lbf)
10.INSTALL REAR AXLE SHAFT LH NUT
(a)Install a new axle shaft LH nut.
Torque: 294 Nm, (3,000 kgf cm, 217 ft.lbf)
11.REMOVE REAR DISC BRAKE CALIPER ASSY LH
12.REMOVE REAR DISC
13.INSPECT BEARING BACKLASH
14.INSPECT AXLE HUB DEVIATION
15.INSTALL REAR DISC
16.INSTALL REAR DISC BRAKE CALIPER ASSY LH
pic 7
17.INSTALL REAR AXLE SHAFT LH NUT
(a)Install a new axle shaft LH nut. Torque: 294 Nm, (3,000 kgf cm, 217 ft.lbf)
(b)Using a chisel and a hammer, stake the axle shaft LH nut.
18.INSTALL SPEED SENSOR REAR LH
19.INSTALL REAR WHEEL
20.CHECK ABS SPEED SENSOR SIGNAL
___________________________________________
Let me know if this helps.
Joe7
Dec 29, 2020 at 3:08 PM
TEGO
  • 9 POSTS
Hi Joe,
This seems fine. I will now get to work and let you know how I make out. Hope I don't do any damage, lol.
Thanks a lot.
Tego
Dec 30, 2020 at 2:10 PM
  • 110,248 POSTS
You are very welcome. Let me know how things work out for you or if you have other questions.
Take care and Happy New Year.
Dec 30, 2020 at 2:27 PM
TEGO
  • 9 POSTS
Hi Joe,
Hope you are having a Happy New Year. I am back with other questions. Please take a look at the attach pictures. After I cleaned up the rust on the spindle, do I apply bearing grease to the gear portion? (picture 1) Second question, what tool do I have to use to get the parking brake cable from the attach brake hardware in order to run it through the new backing plate? (picture 2).
Thanks,
tego
Jan 4, 2021 at 1:04 PM
CARADIODOC
  • 34,413 POSTS
I use a large side cutter for electrical work. Squeeze the jaws between the loops of the spring, then use it to slide that spring back away from the parking brake lever. Squeeze tighter to hold that spring to the cable. That will provide plenty of slack to allow the cable to be tilted out of the lever.
Jan 5, 2021 at 8:34 AM
TEGO
  • 9 POSTS
Hi Joe,
Thank you, that was so easy (lol). I had to laugh at myself for the fact that I did not think that the spring could move.
Tego
Jan 10, 2021 at 11:48 AM
  • 110,248 POSTS
Tego,
Glad to hear you got it fixed. LOL I'm presently in the hospital and am beyond ready to go home.
Regardless, I'm glad it's fixed. Take care and feel free to come back any time in the future.
Jan 11, 2021 at 4:50 AM
TEGO
  • 9 POSTS
Sorry to hear. Wishing you a speedy recovery and my prayers are with you.
Jan 12, 2021 at 4:45 AM
  • 110,248 POSTS
Thank you. Let us know if we can help in the future.
Jan 14, 2021 at 7:00 PM
TEGO
  • 9 POSTS
Joe,
I was doing very well (see attached), now I am stuck and the new nut is not tightening far enough. I think I messed up some of the thread. Yes, I knew you told me to unstake the nut before removing it but I forgot to. Is there a way I can easily repair the spindle thread?
Tego
Jan 18, 2021 at 2:35 AM
  • 110,248 POSTS
Is it the spindle or the nut which is bad? I can't tell by the pic. As far as repairs, it really is based on how bad the damage is. I know there are thread cleaner sets that function as taps that will repair a damaged thread, but if they are too badly damaged, it won't help.
Can you get a close up of the damage so I can better see it?
Jan 18, 2021 at 11:09 AM
TEGO
  • 9 POSTS
I believe the spindle thread got messed up when I tried to tighten the nut using socket and wrench. Because it got stuck at the point where the cut out starts on the spindle. I took it off and tried hand tighten it but that's as far as it will go. I think it needs to go another 2 inches to be flush with the bearing hub. I hope I explained it good enough so you can understand it. the picture shows the spindle on both sides and with the nut up to cut out.
Thanks,
Tego
Jan 19, 2021 at 12:15 PM
  • 110,248 POSTS
The threads on the axle look really good. Are you sure the nut isn't bad?
Jan 20, 2021 at 8:29 AM
TEGO
  • 9 POSTS
I bought a new nut (M22 x 1.5mm Dorman Spindle Lock Nut Kit 615-224) and that one is not going on at all. Unless it is not the right size. What do you think?
Thanks for your help.
Tego
Jan 20, 2021 at 1:50 PM
  • 110,248 POSTS
If it is the wrong one, it won't work. Are they sure at the parts store that they gave you the right one? Can you make a video showing what is happening with both? If I was there, it would be much easier, but chances are we are a thousand miles apart. LOL
On the axle, inspect the starter threads to make sure they weren't damaged.
Let me know. In the worst case, we will need to replace the axle. I will help you through that and they aren't that expensive.
Also, I looked at your pics again and everything looks good. I'm not sure what is causing the problem. Ask the parts store to pull an axle for your vehicle and then compare the axle nut they sold you and the one on the new axle.
Let me know what I can do to help.
Jan 21, 2021 at 7:56 AM
