Would not start so I tried to jump and switched out the battery. It still did not start. I have checked all the connections and had a loose connection on the battery ground. Now it will not start with the key. I can manually engage the starter relay on the fuse box and it will start right up. I have changed out the relay fuse and the same thing happens. I can not get the starter relay to engage on its own. Any idea what I can try?
Dec 17, 2018 at 8:52 AM
