Dumping fuel
240,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CHEVYGAL4LIFE
Okay truck was dumping fuel out of the tailpipe. Had to replace the spider fuel injection system. Had to have the truck towed home because my mechanic said not to drive it like that. So got someone to tow it home and was very specific about my mechanic saying not to drive it with it dumping fuel like that. However the person just ignored what was said and had is girlfriend drive it from my mechanics to my house. Which is about 6.2 miles. Anyway I took the top of the motor apart and replaced the whole spider fuel injection system. Put it all back together, drained the oil (which smelt like straight gas). Anyway now it is back together and starts but runs real rough and got fuel dripping out the muffler. I know that he probably has my new plugs fouled out, but how do I get the fuel out of the muffler and every where else it is not suppose to be? And how to I check everything to make sure it is all clear before driving it? Been down for a while now and really need to get back on the road ASAP.
Mar 10, 2018 at 2:21 AM
Good evening.
I would remove the plugs and clean them up. put a little oil in each cylinder to help build back some compression.
You will have to let it run to get the remaining fuel out of the exhaust. give it some time to smooth out. if it does not, then do a compression test on all the cylinders to be sure there is no cylinder damage from the wash down with fuel.
Mar 10, 2018 at 7:02 AM
