Dual heat not working properly
113,000 MILES • V8 • 2WD
RICK WHITE
On the way to work this morning cold air blows on the driver side and heat on the passenger side no matter what I put the temperature on the driver side only stays cold.
Jan 25, 2021 at 7:27 AM
  • 110,248 POSTS
It sounds like the blend door actuator for the left side has failed. What I would recommend is to remove it and see if it responds when you actuate it to work.
Here is a link that shows in general how one is replaced:
Here are the directions specific to your vehicle for replacement. the attached pics correlate with the directions.
______________________________________
2005 Cadillac STS V8-4.6L VIN A
Air Temperature Actuator - Left
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures Air Temperature Actuator - Left
AIR TEMPERATURE ACTUATOR - LEFT
AIR TEMPERATURE ACTUATOR REPLACEMENT - LEFT
REMOVAL PROCEDURE
1. Remove the left closeout panel.
pic 1
2. Disconnect the left air temperature actuator electrical connector from the actuator.
3. Remove the left air temperature actuator screws.
pic 2
4. Remove the left air temperature actuator.
INSTALLATION PROCEDURE
pic 3
1. Install the left air temperature actuator.
2. Install the left air temperature actuator screws.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the screws to 1 N.m (9 lb in).
pic 4
3. Connect the left air temperature actuator electrical connector to the actuator.
4. Install the left closeout panel.
Jan 25, 2021 at 12:08 PM
