Dual electrode spark plug, and gap setting
2004 TOYOTA TUNDRA
210,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
EMARN
Manual calls for dual electrode spark plug. I find none for sale, and the Denso model number the manual references is a single electrode plug. Why the discrepancy? Are two electrode plugs still available? As to gap setting, the manual calls for .31. In your YouTube video you state the setting should be .44. The Autolite Iridium plugs I purchased are also set at .44. Is the manual stating .31 because it expects a dual electrode plug, or is that indeed the correct gap for any plug?
Aug 17, 2018 at 12:06 PM
Good evening.
The gap is indeed 31.
Gap 0.8 mm (0.031 in)
As far as the plugs, below are the recommended plugs for the engine.
Recommended spark plugs
DENSO K20R-U
NGK BKR6EYA
Aug 17, 2018 at 12:17 PM
