DTCs=fail
83,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BENJAMINTHERERRIBLE
  • 58 POSTS
This car failed (Colorado) emissions test for the following DTCs:
p0010
P0011
P0013
P0014
I understand that these are camshaft position sensors. Does this mean I need to replace them? And is there a written procedure for it?
Jul 14, 2019 at 9:27 PM
STEVE W.
  • 15,423 POSTS
Welcome back. Those codes are indicating that the cam sensors are working but that the cams are both advanced farther than they should be. The most common reason for these codes is low or dirty oil as it causes the solenoids to stick. The first thing to do is check the oil level and/or if the oil hasn't been changed in a while, change it. Be sure to use the correct oil. If that doesn't do anything then the next step would be to use a scan tool to watch the cam timing as you disconnect and reconnect the actuators and see if the cams change in timing. If they do change but you still have the code it is more likely that you have a failing timing chain. If the cams don't change then you would replace the actuators and test again.
Jul 15, 2019 at 1:45 AM
BENJAMINTHERERRIBLE
  • 58 POSTS
Replaced both actuators. After several drive cycles, code has not returned. Thank you again!
Sep 7, 2019 at 12:35 AM
STEVE W.
  • 15,423 POSTS
Thanks for the update. Glad to hear you got it sorted.
Sep 7, 2019 at 8:11 PM
