Dtc code 9
150,000 MILES • 2.0L • 4 CYL • AWD • AUTOMATIC
MUSAB KHALID
I have different problem dtc code 9 what is my problem blower motor on but A/C compressor not going to be on.
Jun 3, 2017 at 2:11 PM
HARRY P
  • 2,292 POSTS
According to AllData, there is "a problem in the air mix control linkage, door, or motor." This is the door that switches your HVAC unit from A/C to heat, and vice versa. A problem here might have it stuck on heat even when the A/C is being used. I cannot seem to find an exploded view of the HVAC unit, but it should all be behind the dashboard.
Jun 3, 2017 at 10:15 PM
