DSG 02E Valve body?
50,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
TJHOGAN69
Replaced valve body on the car listed above DSG 02E auto transmission. also replaced oil and filter. Is there anything else that needs to be accomplished before i start it up and take it for a test drive?
Thanks,
Tim
Mar 18, 2025 at 5:38 AM
  • 55,694 POSTS
Yes, I would scan the car for codes and then clear them before you drive it. If you think there is a problem, please upload a short video. Did you check the fluid with the engine hot? If not, this needs to be done.
Mar 19, 2025 at 3:37 AM
