Key stuck in ignition and wont start again
180,000 MILES • 1.9L • RWD • MANUAL
COLIN FAIRFAX
After riving I went to turn off the engine. I could not turn off the engine and the key would not move. Got the key out after hours. Ignition light still on, but it will not start and rest of ignition lights do not come on.
Jul 6, 2016 at 7:18 PM
RIVERMIKERAT
  • 6,106 POSTS
That sounds like a problem with the ignition switch. It is probably the tumblers inside the key portion of the switch or the springs that keep tension on the tumblers.
Jul 13, 2016 at 2:05 AM
