DRUM BRAKE SHOES SELF ADJUSTER
220,000 MILES
XCHCUI
  • 91 POSTS
In the drum there is a self adjuster as the one in the following photo:
http://produto.mercadolivre.com.br/MLB-731207384-pino-regulador-sapata-freio-astracorsa-original-gm-90182369-_JM
As you can see, there is between the long hollow metal(where the thread gets into)and the star a kind of black spring/ring,which is compressed between them,while two small edges of the spring/ring sits in a slot at the hollow metal round edge.(which has,actually,two slots a round it).
I found a similar drum kit,where all the parts are the same, but it does not have that spring/ring and the round edge of the hollow metal is smooth.(no slots).
My question is; can i install the one that is without the ring/spring?
Is it important to use that spring/ring?
May 22, 2016 at 11:19 PM
HMAC300
  • 48,601 POSTS
We do not have these cars in US so we have no information on them. If it is like ours I can try to see what I can do.
May 23, 2016 at 12:41 AM
XCHCUI
  • 91 POSTS
If there is someone that have a good knowledge how does the self adjuster work, i think he probably could answer my questions.
All the self adjuster work more or less at the same principle(with small differences).Is there someone professional that may answer my question?
Or at least tell me if i must use that spring/ring(red arrow at the attached photos).Since my spring/ring had been broken.
May 23, 2016 at 3:19 AM
HMAC300
  • 48,601 POSTS
Yes this part must be used in order for the self adjuster to work correctly
May 23, 2016 at 4:58 AM
XCHCUI
  • 91 POSTS
Can you explain what is the function of that spring/ring? And what might happens if it be omitted?
May 24, 2016 at 1:05 AM
XCHCUI
  • 91 POSTS
I mean,how exactly it will cause the self adjuster to work incorrectly?
May 24, 2016 at 1:09 AM
HMAC300
  • 48,601 POSTS
it means that spring pressure would no longer be put on adjuster wheel and would not work at all or would run away and spin freely so that your brakes would drag on that wheel wearing the brake shoes out.
May 24, 2016 at 5:00 AM
XCHCUI
  • 91 POSTS
THANKS HMAC300.
May 24, 2016 at 3:14 PM
