Engine will not crank
94,301 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CAMC61
  • 36 POSTS
Hello, I just purchased this car. I drove car home parked it and this morning it will not even crank the engine. There is a little red flashing light by the radio volume knob. radio when turned on says code. Will this keep engine from starting?
Apr 6, 2017 at 4:27 AM
  • 55,688 POSTS
The red flashing light will not keep the engine from cranking over. It sounds like the starter has gone bad, here is a guide that will help you test the starter and see if that is the problem.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 8, 2017 at 5:10 AM
