Drop to one side after sitting for 2 days
96,250 MILES
TENNIS52
I would like to know why my Mecede CL 500 drop on the right side after sitting for 2 days. I have taken it to the repair shop and had valves replace and was took that was the problem. that cost me $686.00. Two month later the same thing happen again. This time I was told it was some kind of filter was bad. That cost $265.00. Now I believe I am giving money away. All I get is try this if this is not it we will try something else. But I continue to spent money. Can you help me please. I also see someone else is having the same problem. Thank you Randy 404 936 6891
May 27, 2013 at 11:37 PM
KHLOW2008
  • 41,812 POSTS
For the wheel that is dropping, it has a leak in the circuit and taking 2 days to drop would mean the leak is very minor, which would make it difficult to locate.
May 28, 2013 at 12:42 AM
TENNIS52
Is this something that I need to be concerned about. I have spent a lot of money on this problem. Is any more damage being done by continuing driving. Thank you
May 28, 2013 at 1:17 AM
KHLOW2008
  • 41,812 POSTS
If the suspension goes back to normal while driving, it would not be much of a problem for now but if it stays low, ride quality and suspension would be affected.
May 28, 2013 at 1:36 AM
