The car has a constant drone that's the is the same at all speeds up to 80klm. Then stops at 90klm and above. More so on an uphill and not so much on downhill.
Have had 3 mechanics look at it and have had the serpentine belt replaced as well as belt idler pulley bearing, tail shaft centre bearing, a front and rear tyre replaced and wheel alignment.
The noise is still droning and I don't know what else to do.
Any help would be appreciated.
Thanks, Tony
Thanks, Tony
Jun 19, 2021 at 1:31 PM
