Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Exterior Light
Daytime Running Light
DRL disconnect
2003 TOYOTA CAMRY
150 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BASET OMAR
MEMBER
1 POST
Hi, I live in Nurt Africa and my car is from Canada so we do not need DRL. how I can disconnect it? thank you for your help.
Jul 8, 2017 at 3:52 AM
Experienced Mechanic
The easiest way to stop the DRL from working without effecting other circuits is to remove the bulbs or fuse.
Here is a guide that will show you what you are in for when doing the job:
https://www.2carpros.com/articles/drl-light-bulb-replacement
Cheers, Ken
Jul 10, 2017 at 4:10 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
