Driving in too high-water flooding and the check engine light is on?
115,000 MILES
GASHUBUZU
There was no issues before this happened, but after I drove in too high water flooding the engine light is on.
Sep 4, 2022 at 8:12 AM
  • 110,248 POSTS
The first thing I am going to suggest is to have the computer scanned for diagnostic trouble codes. If you don't have a scan tool, most parts stores will do it free of charge.
Next, if there is nothing retrieved and since you were in high water, I would like you to have the can-bus scanned. CAN stands for controller area network. Basically, the different computers/modules are tied together via a few wires so they can communicate back and forth. If there is a code, this type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how to do it:
The difference between scanning the CAN and what most parts stores can do is the tool. Most parts stores will only have a scanner that can read engine codes.
Let me know your thoughts or if you have already had this done.
Sep 4, 2022 at 2:11 PM
