ABS lights on
230,000 MILES • 1.4L • AUTOMATIC
DARCY CANNIOTO
Hi, i just had wheel bearings changed and now all my dash lights are on, the Brake, !, ABS, VSC. The garage who changed them said the wheel bearing they just put on already went bad without me even driving that and it kicked the lights on. I want to know what would have caused this or if that would actually even be the case. i just had them replace all bearings/struts/and the rear wheel drums too. plus tires. Any help would be appreciated!
May 29, 2017 at 11:25 PM
  • 55,694 POSTS
It sounds like they didn't connect the wheel speed sensor wiring which would cause the problem you have described. Or the wheel bearing has a defective sensor on it.
Have them read the ABS codes to see what is missing. you may what a different shop to look at it.
Cheers, Ken
Jun 1, 2017 at 4:44 AM
